is that even internaly the same engine (gearbox, oil pump,....)
I expect yes, but I've never done it before.can i make an 560 of it,
this is not the problem because the piston stroke of the 350 and 560 are different, so you have to use the crankshaft of the 560.would the cranckshaft be strong enough ?
not really, it depends which roller bearings are assembled.so would ii improve the KTM by installing an aprilia engine you think ?
piston strokehe crackshaft is that change is that for the stroke or for the rigidity ?
if the weight of the piston is the same, it should work.I could also opt for an bigger bore in combination with the 350 stroke, but will it be ok with the internal engine balance ?
