@Weity1980: Jetzt habe ich doch mal tatsächlich im Handbuch nachgeschlagen. Dabei bin ich über folgendes gestoßen:
Tachometer output TACHO
The tachometer output is compatible with most on-board devices used on motorbikes. Number of pulses per one revolution and possible corrections are set using software.
TACHO is supplied by 12 V voltage and GND. TACHO output will be connected to TACHO (pin 15).
The revolution indicator output is not compatible with on-board devices used on old Honda motorcycles from the 1990s (ignition units with OKI 16pin connector). Unit can be equipped with revolution indicator output compatible with these on-board devices (marked HONDA TACHO).
Multifunctional outputs
The unit contains two multifunctional outputs (Power Outs). Outputs are type NPN opek collector (it provide ground when is switched on). Outputs can switch resistive or inductive load up to 2 A. Outputs can work with various modes preselected with software:
Fuel pump - it is switched on for 4 seconds after unit switch on and always when engine is running.
Gear shift light - two stage gear shift light.
PowerJet Honda - behavior like PowerJet at Honda RS125.
Special - switch on and and switch off according curve/map with pulse-width modulation possibility (powerjet). Special PWM - continuous control with pulse-width modulation according curve/map (powerjet for example).
Speciál pulse - continuous control using the pulse length according curve/map (oilmaster for example).
Multifunctional output 1: Load should connected with one outlet to POWER OUT 1 (pin 3) and second outlet to +12 V. Multifunctional output 2: Load should connected with one outlet to POWER OUT 2 (pin 12) and second outlet to +12 V.
Der Erste Versuch war über Pin 15. Also das Tachosignal - Da lagen 12 Volt an.
Der zweite Versuch war über den "Multifunctional output" in der Einstellung Fuel Pump - und hier steht tatsächlich in der Anleitung: it provide ground when is switched on. Fehler gefunden!
Allerdngs sehe ich keine Einstellung die mir beim einschalten der CDI ein Dauerhaftes Minus gibt. Damit scheint der "Multifunctional output" für mich keine Lösung zu sein.
@Yachti: Mein Kabelbaum berücksichtigt im Moment keine "Sicherheitsfeature". In der nächsten Ausbaustufe werde ich den Seitenständer und das Signal von der Ganganzeige in die beiden Eingänge hängen. Dann kommt nur ein Zündfunke wen mindestens einer der beiden Signal neutral ist.
Im Moment funktioniert alles nur, weil ich das Hilfsrelais brücke.
