Hey, I was wondering if you could make a drawing about how to install the lights and other parts....? It would he really helpful for me... So maybe if you have some time free... Thanks in advance!!Yes thats 620. You do not need the original switches. But it would help using the original wiring diagram. There is this Kind of combo switches... Used in exc Models. Works great. U Just have to add a Relais for indicators. Tell ne what Kind of Switch you buy, i'll try to draw Something then. Kombischalter mit Blinkerschalter für KTM EXC Modelle ab 1998 - 2016
Hey again,Yes thats 620. You do not need the original switches. But it would help using the original wiring diagram. There is this Kind of combo switches... Used in exc Models. Works great. U Just have to add a Relais for indicators. Tell ne what Kind of Switch you buy, i'll try to draw Something then. Kombischalter mit Blinkerschalter für KTM EXC Modelle ab 1998 - 2016
Pinout? What you mean?U have the pinout for the combiswitch?
I don't have, was not included. But tomorrow I will open it and look for it!Which color is connected to which function?
I made a drawing. I think it's all correct...Or use Multimeter to Check. I'll try to Paint Something then tomorrow.
I dont have the original anymore. The drawing I made at the start of this post few weeks ago is all there is on the bike.You want to use some of the original cables? Or complete own tree? Would make things easier, because U would Not have to use the keyswitch. Not understood Ur light pinout. Here es what i got for now...
The drawing I made now is just how I checked the combiswitch with the multimeter. You can see on the picture all the different colors.
I also don't have a keyswitch on the motorbike.
Ok... I give an example. I use the Multimeter to check when there is a connection.Okay, i'll draw you Something from Generator then also. I Just dont get what Position switches what function in Ur new combiswitch.
Sorry, I can notn help. I am really bad with electronics...Yeah. Its Just about the light. The Rest ist time and already in the drawing. Updated the color for 12V from yellow blue to Red white. Cuz No Key switch, No yellow blue needed.
Yes thanks. The rest is clear to me indeed!I'll try to find the pinout and Draw the Rest. Can you follow the Rest of my drawings?
